Rick Mostaert
- Dec 14, 2001
Thanks to all of the great information here I have finally started my basement this winter after 6 years of thinking about it. I have finished framing and running conduit for the electrical in just two months time working mostly by myself and only on weekends. Plan to complete in August due to upcoming boating season. Don't watch much TV in the summer.
First some quick advice...
If you are framing with wood and own a compressor, invest in a framing nail gun. Incredible time saver! Well worth $200.
Conduit bending is not that hard and leaves options open for future for additional circuits or lighting. I live in the Chicago area and it is required for all wiring.
Now for my questions. Here is the layout for the Home Theater, pool table area and wet bar. Questions and explantion below. (Hope this works, if not here is the link http://www.enteract.com/~mostaert/basement.html
Explanation
Explanation
- The TV is at the bottom with the equipment rack to the right in the recess
- The prime 5.1 speaker locations are in solid blue boxes.
- Alternate speaker locations are in blue outline boxes for the sides.
- The red solid boxes are a possible location for rear surrounds mounted to a soffit
- The red outline boxes are another possible location on the rear wall.
- The green box is a support pole framed 12" square
- The light blue wall in the middle will be a half wall/bookcase
- Sub placement is up in the air but most likely in the corner by equipment rack or by the half wall
- The beam and soffit have a 6'8" height from floor and the ceiling is a drop ceiling at 7'3"
- Wet bar sink is under stairs, bar will move mostly under stairs to make room for 8ft table.
- Would bipolar speakers work in the prime locations or would it be better if they were back further?
- Since I will be upgrading my receiver, would a 6.1 or 7.1 layout work in this room and which speaker location would work best?
- My main question is will that half wall or support pole mess up the sound? Not much I can do about the pole but maybe speaker location my make a difference?
- Will that recess mess up the sound? If so, what are my options?
- Check out my current equipment below. Should I consider larger mains? I have until November to take advantage of the Paradigm 1 year upgrade deal. In my current living room I listen at about 10dB below reference.
- Feel free to comment on anything else.[/list=1]
Current equipment- 2 Paradigm Mini Monitors upfront, CC370 for center, Titans for rears, PDR10 sub
- Tosh 4700 DVD player
- Sony DE945
- DirecTV non-5.1, non-HDTV
- At least 55" 16x9 RPTV
- New receiver
- Sub with more lower extension
- ADP170s for sides
- DirecTV HDTV and OTA HDTV receiver
- Possible rear surrounds
Thanks in advance for any advice or comments.
Rick
