Tom Steele
- Sep 12, 2004
I just lost my second Yamaha YST-800 under similar circumstances and am looking for help, and suggestions as to what might have happened, and how I might repair the subs.
Last week, my power went off. This is fairly common for me. (Probably twice a month in the Summer.) It is usually uneventful.
Since the power was off, I went downstairs in the family room by a window and was reading.
I was lying next to the subwoofer when the power came back on. It was on a Panamax surge protector. It sounded like something was powering up, then I heard a noise like a match being struck. My stomach sank, and I turned on the system and sure enough, the sub exhibits the same symptoms as the previous one: It comes on, the green led is glowing, but it makes no noise.
I have tried switching the sub to "auto-on" when it senses a signal, but this does not work. Then the LED just sits on red and never acknowledges the signal. The power is on, but there is no noise coming from the sub.
The only differences in this scenario and my first YST-800 failure are that the first sub was not on a surge-protector, and I wasn't there when it fried. The symptoms are the same.
Surely this is a known problem. I can't have been the only unlucky person to get two bad ones.
Anyone with any experience with this, or ideas where to look?
I'd also add that in both instances, NOTHING ELSE in the house suffered any ill effects. JUST the subwoofers...
TIA,
TIA,
