Yamaha...why RXV and HTR ?
Discussion in 'AV Receivers' started by Mirko, Aug 19, 2003.
  1. Mirko
    Mirko Agent
    Aug 14, 2003
    41
    I am leaning towards a Yamaha receiver for my HT. There seem to be some models designated as RXV something and some as HTR something. HTR 5660 and XRV 630, for example. What do these two three letters mean? Is there any significance to the two "lines"?
    Having said that, the RXV630 for less than $250 seems like a real deal. It's almost as if I can just buy that for now, while I get smart, which I suspect will take quite a while yet.
  2. David G Greene
    David G Greene Stunt Coordinator
    Jul 28, 2002
    120
    RXV has better parts in them,than the mass market HTR.
    [​IMG]
    [​IMG]
  3. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
  4. Mirko
    Mirko Agent
    Aug 14, 2003
    41
    Thanks for the very good explanation. I have gone back to the Yamaha site and you are absolutely correct!
    So then, how I compare model numbers. This is way more difficult than it has to be. Model numbers between the two lines are different as well.
  5. Edwin_C
    Edwin_C Stunt Coordinator
    Jul 21, 2003
    113
    HTR-56x0 RX-Vx40
    the x is the equivalency term.
    ex: HTR-5640 is the same as the RX-V440
    HTR line only goes up to 5660.
  6. Mirko
    Mirko Agent
    Aug 14, 2003
    41
    Let there be light!
    Thanks for your help
  7. David G Greene
    Jul 28, 2002
    120
    Sorry about my wrong info on the Yamaha line.
    I feel so.........dumb.
    [​IMG]
  8. RobWil
    RobWil Supporting Actor
    Mar 17, 2003
    733
    Don't worry...a famous man once said "Half of being smart is knowing what you're dumb at"....now ya know , I guess, so you're halfway there! [​IMG]
  9. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I just got the Yamaha RX-V2300. Is there an equivalent HTR model then? You mentioned it only goes up to the HTR 5660.
  10. Josh~H
    Josh~H Stunt Coordinator
    Jul 21, 2003
    126
  11. keithVANhorn
    keithVANhorn Stunt Coordinator
    Sep 22, 2002
    57
    The RX series is for "comision" based sales. And the HTR is for "non-comision" sales. For example, Best Buy has HTR. American has RX. I think that is the main reason. As far as I know.
  12. Phil Iturralde
    Phil Iturralde Screenwriter
    Oct 7, 1998
    1,867
