Manny G
- Nov 8, 1999
Hello,
I was hoping to get some suggestions before heading to the service center. I have a Yama RX-V995 I have had since 1999 and for the past number of months the volume knob is not responding to the remote at times. The display shows that the remote is "telling" the receiver to adjust volume, but the knob does not turn until you get up and nudge it a bit. Then it will work fine for a time, but it happens again. Though getting up and adjusting the volume was fine in our parent's day, and I probably could use the exercise, I have gotten quite accustom to the remote!
Has anyone one had similar problem? Is there a consumer level fix that I should try? Other helpful suggestions?
Manny
Manny
