Yamaha S2300 BM for SACD
John-Miles
I am finding that the bass outpout on my player is much much lower in SACD. is there a way to fix this or should i use an attenuator?
Kevin C Brown
Producer
Hee, hee. Pioneer players do the same thing, and everybody thought it was Pioneer's fault.
But it's not. It's a stupid incongruity between DD/DTS where a 10 dB boost is applied by any processor, vs SACD/DVD-A where it's not.
Here's what I did: In your processor/receiver, purposefully set the sub level about - 5dB from the speakers. Now, adjust the sub's level control on the sub itself so that you get the right numbers for DD/DTS. Now, if you adjust levels on the Yamaha, you should find that if you have the sub adjusted to about + 5dB compared to the rest of the speakers, you are golden.
John-Miles
Yeah thanks Kevin, but the problem withthat is on DVD-A the bass is at a great level, its only on sacd that it is lacking... and severely so.
Keith Mickunas
Effects Supervisor
Pump up the subwoofer setting for the SACD side only. That's a completely separate control on the 2300. Adjusting the subwoofer from the DVD menu does nothing to SACD.
Keith Mickunas
Effects Supervisor
Switch it to SACD mode, then go into the setup menu. Its explained on pages 31 and 32 of the manual and is a bit detailed for me to explain here. Each increment on the speaker adjustment for SACD is 0.5dB.
Michael St. Clair
Producer
I have not noticed this bass weakness.
Did anybody buy the $35 test disc from Sony? I've been waiting for opinions. I'd sure like SACD test tones.
John-Miles
The sub adjustment I found looked linda like a balance for the sub, there was a L and R end to the scale is that what you were refering to?
Keith Mickunas
Effects Supervisor
John, the test tones and such for SACD are pretty stupid. Its indicating that it puts out a tone via the mains and the sub so you can adjust the sub level. It makes no sense whatsoever. The manual says this for the right rear speaker level adjustment:
Select BALANCE RS, then press ENTER. The unit displays the following indication, and the left and right main speakers and the right rear speaker output a test tone at the same time.
L/R - - - + - - - RS
Moving the slider left and right adjusts the volume of the right surround and does nothing to the mains. Now why anybody would want a test tone out of three speakers at once I have no idea. So choose Balance SW and adjust it. Unfortunately you'll have to do it by ear because its just not real accurate.
Bigguz
