Yamaha RXV-1400 with aragon 2005 power amp?
Discussion in 'AV Receivers' started by Jesse Sharrow, Jan 28, 2004.
  1. Jesse Sharrow
    Jesse Sharrow Supporting Actor
    Jul 11, 2003
    745
    Would this be a pretty good idea for an intro into seperates? I will obviously upgrade the preamp to a aragon preamp. But for an intro into seperates do you think this is alright?
    I have a pair of boston VR-950's on a yamaha rxv-440. At higher volumes it seems to distort and they seem kinda strained. I think that having more power would give me better dynamics. What do you guys think?
  2. Charles Gurganus
    Charles Gurganus Supporting Actor
    Mar 2, 1999
    689
    It is a great amp! You will have all the power you will need for just about any speakers.
    When you go to seperates, YOU don't mess around.
  3. RobCar
    RobCar Stunt Coordinator
    Nov 27, 2002
    201
    I'd buy the 1400 and use it by itself first, then get the amp later if you still feel like you need to. The 1400 will have a lot more power than the 440. Plus, Yamaha and Boston sound really good together.
  4. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    I have a Yamaha RXV1400/Rotel RMB-1095 setup that sounds fantastic.
    Kevin
  5. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    I like Yamaha. I like Aragon. But I have to think, if you're going to spend that much money for that good an amp, why not get a pre/pro and dump the Yamaha receiver? Outlaw, Rotel, Sherwood, Integra, etc, all make good value pre/pros. Or, maybe that's your next step. [​IMG]
    I had a Yamaha RX-V793. Then added a 2 channel Nakamichi PA-5AII power amp. (Stasis class, a la Threshold and Nelson Pass.) Then I added an Acurus 100x3 amp. Then I traded up to a a Sony TA-E9000ES pre/pro. This was 5 years ago. [​IMG]
    One last thought. If you *ever* think you might want to go to 7.1, you might want to think about getting the 2007.
