Yamaha RX-V661 question (1 Viewer)
I connected my DVD player using the Component cables from the player to the receiver. I then connected the HDMI cable to the Mits 52327 RPTV(using DVI/HDMI adapter).
I also connected the digital audio because the mits has only 1 DVI.
I can get audio but no video. I set the up convergence to on then tried off. Still no picture. Is the problem with the receiver no being able to upscale the component video signal ti HDMI?
I might have to connect the component cables straight to the Mits.
Superman1213
