Yamaha rx-v650 protection (1 Viewer)
Spencerbloke
Paul
Help please.
Yamaha rx,-v650 goes into protect mode when set to 8ohms.
6ohms ok.
Now. All output stages have been replaced.
8ohms i get dc voltage on Sbl channel at power up but not when set to 6 ohms.
Any help on this would be welcome as yamaha were not helpfull at all.
Mike Frezon
Rexford, NY
Moved this thread into the proper forum (AV Receivers) to get the proper eyeballs on it.
Welcome to the forum, Paul! :D
Good luck.
Lord Dalek
Joel Henderson
Well I don't know what you're trying to do with it but please understand the receiver is about 20 years old. You might want to consider that seeing as it doesn't even have HDMI.
Spencerbloke
Paul
Not everyone needs it to have hdmi. Its just for the audio and has been working faultless for years untill one day.
Not wanting to replace as new ones are mega expensive and its only the LSB channel thats causing issue
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
That’s certainly understandable. It shouldn’t be hard to find something affordable to meet your needs from Craigslist or at a local pawn shop. Personally, I hardly ever by new gear.
Wayne A. Pflughaupt
DaveF
Catfisch Cinema
Dave
Not helpfull
It’s not what you want to hear. But it is helpful. Your 20 year old AVR is dying from electronics failure. If John says it’s dead and best to replace than attempt repair, it’s advice I’d give real thought to.
Or, since 6 ohm works, use it in 6 ohm mode until that dies.
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Can’t help but agree with Dave. Repairs to electronics are not cheap. And at its age, there’s a very good chance that whatever parts are needed to make the repair are no longer available.
Wayne A. Pflughaupt
Al.Anderson
Al
What speakers are you using and has anything changed?
I don't know what this means, so maybe I'm missing something, "Now. All output stages have been replaced."
CoolMovies
