Yamaha RX-V595 Switched Output
Discussion in 'Archived Threads 2001-2004' started by John Gido, Feb 11, 2002.
  1. John Gido
    John Gido Second Unit
    Jun 18, 2001
    312
    Anyone have any thoughts on why the switched AC outlet on the rear of this unit might stop working? Went to shut off the unit (places the unit into stand-by mode) and the equipment connected to the switched outlet remained ON.
  2. RichN
    RichN Stunt Coordinator
    Jan 15, 2002
    72
    Sounds like your "switched" outlet suddenly became permanent. The only suggestion I have is to unplug the main unit completely and hopefully, the "switch" will reset itself, otherwise, you may have to take it in for repair. A switched outlet is pretty simple, as you probably already know. A switch (relay) makes or breaks the connection between your AC voltage at the plug and the slave unit that is plugged into it. When you turn off the main units power the "switch" should open and disconnect the AC from the slave unit.
    Sorry, I couldn't give you more help.
    RichN
