Yamaha RX-V2500 Fan
Discussion in 'AV Receivers' started by EdKBecker, Oct 9, 2005.
  1. EdKBecker
    EdKBecker Extra
    Mar 8, 2004
    22
    I've read about some people saying they can hear the Yamaha Receiver's fan when it comes on in high heat conditions.
    Well, I set mine to "always on" and I'll be dammed if I can hear it at all. Can somebody tell me where it's located so that I might visually see it running?
    I talked to Yamaho twice plus a tech at one of their authorized service centers and I never got a straight answer as to where it's located.
    They only said that it is quiet.
    TIA
  2. Thomas_A
    Thomas_A Second Unit
    Feb 2, 2001
    398
    I was looking on the Yamaha web site too check out the line. I have the 2400 and I have never heard the fan. So I wanated to make sure it had one. Still dont know if it does. Looks Identicle too the 2500...so I assume if there is a fan- its internal. Basically- I've never heard the fan. I have on my DLP TV and my projector...but not on the RV-X2400
  3. EdKBecker
    EdKBecker Extra
    Mar 8, 2004
    22
    As far as I know the 2400 and 2500 are the same, except the 2500 has an advance menu setting whereby you can manually have the fan running.
    I set it to this mode and can hear nothing--absolutely nothing.
