bjarni_b
- Sep 29, 2003
I recently purchased a Yamaha RX-V1400 and was planning to use an existing Adcom GFA-545 (100W x 2) to power the Front L/R speakers. I was reading on the forum that you need to be careful that the gain on the amp is the same as the gain on the Yamaha amp section or else there will be a difference in relative volume of the front speakers compared to the rest of the system.
Is this a factor I should consider or does the YPAO negate this as it will probably adjust the gain/volume of each speaker to properly balance them to each other?
Also, does anyone think that there will be a sonic difference between the amp section of the Adcom vs. the Yamaha that would make a noticeable difference? (Good or bad)
I have always been a fan of seperates (this is why I have the Adcom amp), however, I bought the Yamaha for the processing power, YPAO and the componenet upconversion. Should I leave the Adcom out of the equation altoghether?? Also, the main reason I bought Adcom originally is because my mains are old a/d/s speakers (don't seem to be around much anymore-- still see their awesome car amps though) which are 4ohm and the Adcom handles the load pretty well.
Any advice would be appreciated, I am setting up the system tonight and am not sure if I should just eliminate the Adcom and use only the Yamaha to power the speakers!
Thanks in advance -- sorry for the long post!
Bjarni
Bjarni
