DougWright
- Mar 24, 2000
I am seriously thinking of buying the Yamaha RX-V1 receiver and now would be the time, because I can get the yamaha branded pronto remote until the end of January. But I see in March (or so) the RX-Z1 will be coming out, and it will come with the pronto remote by default.
Should I hold off a while longer and buy the Z or go for the V now?
Also, I see the yamaha is a 6.1 receiver (Matrix and ES) but I now there are some 7.1 receivers. What is the difference here? will I regret it later and wish I had found a 7.1. I liek the yamaha sound but dont think they have any current or planned 7.1 receivers.
Thanks for your advice,
