Yamaha reciever.....good enough??
Discussion in 'Archived Threads 2001-2004' started by Himanshu_S, Apr 11, 2002.
  1. Himanshu_S
    Himanshu_S Stunt Coordinator
    Mar 24, 2002
    93
    Hi,
    I'm considering the following for my HT setup.
    Yamaha 5560
    ND310--Front
    SCS 135 for movies
    since yamaha has A/B switching, I can have surround sound for movies only if I want to. My question is that
    is the Yamaha reciever a good choice? or should i go with sony? Because these speakers are 250w max each, I feel that the reciever is little low on output. Sony has STRDE975 which I think is comparable to this yamaha. the sony is lacking the prologic II support but its 110wx5 (i think) I don't want to spend 500 bucks on a reciever alone since I'm planning to do the whole HT setup under $1000.
    or should I hunt down a dicontinued HTR-5460?
    Thanks for the responses
    Himanshu
  2. Hank_P
    Hank_P Second Unit
    Nov 15, 2000
    321
    19
    110
    I think you should stick with the Yamaha based on your suggestions. The 5560 has A/B selection, DPII AND Pre-outs. That model of Sony has nothing close to touching that and it only 100wx5.
    I was a little confused by the "I can have surround sound for movies only if I want to" ...what did you mean by this?
  3. MatthewJ S
    MatthewJ S Supporting Actor
    Feb 27, 2001
    584
    Sony rates their wattage for the 975 with a 1khz test tone and allows for .7% thd.....the Yamaha rates at all freqs(20-20,000hz) with less than .05% thd......the Yamaha sounds better to boot!
  4. ManojM
    ManojM Stunt Coordinator
    Feb 13, 2002
    242
    I have always found Yamaha receivers to sound better than the Sonys. The Sonys do well in multichannel (DD, DTS) but are not as clean as the Yamahas for music.
