Yamaha receiver and Klipsch towers (1 Viewer)
Sean Normand
Sean
Hi everyone this is my first post.
...and I will be making more because I'm building a hometheatre in the basement. I've bought Klipsch RF-600B towers and a Yamaha RX-V379 receiver for the audio. can someone tell me if I am underpowering these speakers? I have put them LOUD and have not heard distortion but this lovely article http://www.klipsch.com/blog/how-to-buy-the-best-home-theater-receiver/ has me pondering the possibility that I may in fact be underpowering them. Thanks for your help.
Sean
EDIT: links
RECEIVER: http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v379_black_u/
SPEAKERS: https://2d73e25b29782b6d6766-9c8af5cbfef16739445bc76457060528.ssl.cf2.rackcdn.com/RF-600_-_Spec_Sheet_635139050116970000.pdf
ArmSC
Coastal SC
Tony
Hello Sean, welcome to the forum!
You shouldn't have to worry about under powering those speakers. They have a sensitivity of 97dB which means you only need less than 10 watts to get them well over 100dB. That AVR is good for 70 watts at 2 channel so you'll have more than enough to push a pair of those towers to ear bleeding levels.
