Yamaha HTR-5850 or 5860?
Discussion in 'AV Receivers' started by Alex_Hutton, Jun 4, 2006.
  1. Alex_Hutton
    Alex_Hutton Extra
    Feb 22, 2002
    20
    (i know these are 'late' models but i dont need the ipod and xm function on their replacements which is the only difference)
    I only use 5.1 sound, would it be a smart thing though to get the 7.1 receiver? only cost me an extra $50 but that's still money out of my pocket......
    5850 is 6.1
    I can get it to my door with warranty for $255
    105x6 RMS
    5860 is 7.1
    I can get it to my door with warranty for $305
    110x7 RMS
  2. Daniel*
    Daniel* Auditioning
    Jan 5, 2006
    12
    also, the new 5900 series have an extra set of component inputs (3 in, 1 out)
    not sure if that would make up your mind or not
    i' say invest the $50 now and go 7.1, just in case a few months/years down the road, if you'd like to do a simple upgrade to a 7.1 system, you save yourself a few bucks
  3. Alex_Hutton
    Alex_Hutton Extra
    Feb 22, 2002
    20
    well i thought a bit about the newer ones and decided to go for the 5860 or 5960 mainly because of the preouts they offer over the 50 series models.
    It's only $40 extra to move up to the 5960 over the 860 and that gives me the 1 more component input and 1 more coax audio input as well as xm and ipod... so that's probably worth the $40 right>
    305 vs 345
