Clayton_M
Grip
- Mar 3, 2002
Yammy says 75W full bandwidth rated but I have to tell you that I have seen tests where Yammy's like the 620 are shown to be light performers with all channels driven...as low as 27W.
Could you please tell me where you read this? Just curious.
Also, is the 620 reference a typo there? The RX-V620 has 100W per channel. It's the 630 that has 75watts per channel. Also, I have a HTR-5450 (equivalent to the RX-V520) which has 80 watts per channel driving a pair of Paradigm Studio40s (which like lots of power). They sound pretty good to me even at high volumes. So I'm not sure how an even more powerful amp in the same line could be sucked-out when mine is pretty impressive for what it is.
I'm not saying that the Yammie is better then the outlaw, I'm just interested in this "27W" figure and how accurate it is. If the 620 (or 630) really does output 27W when driving all channels, wouldn't that mean that Yamaha is lieing about it's amp?
- Mike
here is what one of the higher end yamahas benched (from s&v mag)
yamaha rx-v1200
1 channel into 8 ohm 124w
5 channels into 8 ohms 50w
2 channels 111w
I wouldn't call the rx-v1200 much "Higher End" than the 630 as it is only one step above it. It is the next model up (took place of the previous RX-V800 I believe. Still, the RX-V1200 is only rated at 75 or 80Wx5 anyway (don't have the specs handy right now), so very similar to the 630. so I would assume the 630 has similar power.
it's true that the rx-v1200 is only one step above the 630, but there is a huge gap between rx-v1200 and 630 because the 1200 the entry into yamaha's high end line. Note that the retail on the rx-v1200 is 899 while the retail on the 630 is 499.
True, but would this lead you to believe that the amp section in the 1200 is so much better than the 630 that the 1200 would bench nearly 2x the power with 5-ch driven when it's only rated at 5w/ch more?
somehow I have a hard time believing this.
Anyway, I guess we won't know for sure until the 630 is on the workbench and actually measured. However I still highly doubt it only puts out 27W/ch with them all driven.
you're right, we won't know for sure until the 630 is benched but considering that the 1200 retails for almost twice as much as the 630, it would not be a surprise if the 1200 delivers almost twice as much wattage compared to the 630.
