Yamaha DVC-6480 DVD Changer - Opinions?
Discussion in 'Archived Threads 2001-2004' started by Robert_V, Feb 17, 2003.
  1. Robert_V
    Robert_V Agent
    Apr 19, 2000
    25
    I wanted to get some feedback.....
    I just ordered the Yamaha DVC6480 DVD 5-Disc Changer to replace my Toshiba SD-3109 2-Disc DVD player.
    I will not be using the progressive video option since I am using a non-HDTV (Zenith, 27").
    Should I expect significant improvement in video and audio?? The Yamaha had built-in DTS in addition to the DD 5.1.
    Let me know any and all comments.
    THANKS,
    Rob
  2. TimothyE
    TimothyE Stunt Coordinator
    Dec 31, 2002
    104
    I also had the Toshiba SD-3109. The jump in audio and video quality was tremendous. In fact I couldn't tell the difference between it and the Panasonic CP72 on any material I threw at it. The CP72 has what most people consider to be equal PQ to the RP82, but it also suffers from many occurances of a component grounding problem.
    The build quality was top notch, and the remote, though cheap-felling, was much nicer than that of the CP72. It also has both optical and coaxial digital audio out, unlike a number of players these days.
    There were only two reasons I didn't keep the Yamaha (I actually got the C920, which is the same thing). First, it didn't have power on/off with the remote. Second, it didn't have the "time remaining" display function, which was important to my wife and I. I still wonder if I could've lived with its deficiencies, but I didn't want to shell out $350 for something that would nag me like that.
    Enjoy!
    Tim
  3. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Robert, the 'C6480 (or 'C920) has gotten some good reviews here, so do a search. In the end, you will have to compare the two players. The 'C6480/'C920 looks to be very solid for the money. I've seen one in stores, but I was not able to demo it. If nothing else, the Yamaha changer will give you DVD-Audio, which should not be overlooked.
