Yamaha DSP-A1, want to upgrade to 6.1!!
Discussion in 'Archived Threads 2001-2004' started by Craig Ball, Oct 14, 2001.
  1. Craig Ball
    Craig Ball Second Unit
    Oct 6, 2000
    284
    110
    Subject pretty much says it. Is there any way to upgrade to a rear center channel without replacing my A-1? The only option i've seen is parasound has an add on unit but it doesn't look to impressive, any opinions? Is there any other way to do this or will i just have to break down and buy a new reciever? (Hope Not)
    Craig
  2. Adam Barratt
    Adam Barratt Cinematographer
    Oct 16, 1998
    2,344
    110
    Adam
    Try the SMART Devices CS-3X jr. add-on processor. You will need an additional power amplifier and a speaker, but from all reports the unit is excellent. ADA also make an add-on unit called the ADA 6.1 Surround.
    Adam
  3. John H
    John H Second Unit
    Nov 27, 1998
    472
    The Smart and Parasound units use the exact same circle surround technology.
    The Parasound adds a remote control for basic functions.
    I have used both the Parasound and ADA units in the past. Between the two I would suggest the Parasound unit.
    Bedroom Based Theater
    [Edited last by John H on October 14, 2001 at 05:16 PM]
  4. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    5,110
    You could also add a Dolby Pro Logic processor. Similar idea to the Smart and ADA boxes.
    Yamaha DSR-70 Pro, DSR-100 Pro, Sony SDP-777ES, Lexicon, Fosgate, Pioneer, etc.
    I am currently using a Shure HTS-5300. A processor from 1989-1992. Judged state of the art way back then. Originally listed for $1200. I got it for $60 (!) on ebay a few months ago. That's far cheaper than the $200 - $300 you'll pay for a new Smart or ADA.
