John Carl
- Aug 26, 2002
Need opinions on this budget sub.
Need opinions on this budget sub.Yamaha 8" 100-Watt Powered Subwoofer
Model: YST-SW105
I think someone is selling a used Home Theater Direct subwoofer over at the hardware for sale board. I think it is goin for about $160. That would probably be your best bet.I found the sub you mentioned. It is an HTD Level 3 powered sub. Anyone have any comments about it.
Or possibly the $99 DLS 10" from Parts Express...Spec for spec, the DLS is not much better than the Yamaha. DLS is only good to 30Hz, though with a 10" driver it may have more kick to it. I've been curious about this sub too, because I've been looking around for another cheap, smallish sub for another room. The Sony is fairly large, and definitely more bass than I need there.
