Yamaha 1400-can I get THX sounds from a THX movie
Discussion in 'AV Receivers' started by Joe_on, Aug 9, 2004.
  1. Joe_on
    Joe_on Stunt Coordinator
    Aug 10, 2003
    52
    If I only have a 5.1 set up. I rented a few movies that says it is THX mastered, and I was wondering if I set my receiver for THX, will I get true THX Mastered digtial sounds?
  2. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Do a search on this forum this had been discussed a million times.THX is not a sound format.There is as such as THX EX,which is the "same" as Dolby EX,and there is THX Ultra II, but that don't require any encoding from the source as it's technically a DSP mode.Check out THX.com for more.
  3. Joe_on
    Aug 10, 2003
    52
    for clarificaton purposes, by pressing THX cinema on my remote for the yamaha 1400, doesnot necessarily gives me better sound-then the default enhanced surround sound for my dvd movies?
  4. Lewis Besze
    Jul 28, 1999
    3,134
    Correct!
  5. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    I thought THX re-eq was engaged when using THX cinema...no?
  6. GordonL
    GordonL Supporting Actor
    Feb 14, 2000
    771
  7. Joe_on
    Aug 10, 2003
    52
    Okay, I read the links,it sounds to me that THX engage does give you a better clean sound. Am I wrong?
  8. GordonL
    Feb 14, 2000
    771
  9. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    You aren't going to be able to tell by READING about it. GO TRY IT and hear for yourself. I personally don't like what THX does to the sound with most movies, THX mastered or not.
  10. Joe_on
    Aug 10, 2003
    52
    Good article. I did listen with THhx mode engaged for the movie, Hildago. It sounded like the enchanced surround sounds, not any better or worse-the part of the train moving along was awesome but I dont know if it would have been the same with the enchanced.
