Yahoo e-mail problems
Discussion in 'After Hours Lounge (Off Topic)' started by ToddJ, Sep 30, 2004.
  1. ToddJ
    ToddJ Second Unit
    Mar 30, 2002
    382
    My yahoo e-mail account just started to widen out. What i mean is, it goes across the screen much, much wider...I have to pan over to see the subject line.Has anyone else had this problem?
  2. Mike Slade
    Mike Slade Second Unit
    Feb 12, 2003
    308
    I don't seem to be having problems with mine. I'm using IE.
  3. ToddJ
    ToddJ Second Unit
    Mar 30, 2002
    382
    It is almost like it is supposed to resize it automatically, but it doesn't.
  4. Kenneth
    Kenneth Supporting Actor
    Jul 31, 1997
    757
    I don't have this problem with IE either. Maybe you check your browser settings. Did you try using another browser to see if it does the same thing? Maybe the scripts are contaminated.
    Kenneth
  5. ToddJ
    ToddJ Second Unit
    Mar 30, 2002
    382
    I have tried it on my roommate's computer and he is using a different browser...It is still like that. It seems like you should be able to move the line separating the "sender" and the "subject." But it doesn't....
  6. Rob Gardiner
    Rob Gardiner Cinematographer
    Feb 15, 2002
    2,950
    Maybe someone sent you a message with a really long subject that is one word and therefore doesn't break?
  7. ToddJ
    ToddJ Second Unit
    Mar 30, 2002
    382
    Thanks Rob! That is sort of what it was.....Problem solved!
