Y-Cable to Split Component Video
Discussion in 'Accessories, Cables, and Remotes' started by Rutgar, Mar 16, 2004.
  1. Rutgar
    Rutgar Second Unit
    Jan 17, 2004
    495
    I need to use the same DVD player to feed my RPTV and my FPTV. Will a quality "Y" cable out of the back of the DVD player work? If not, what's the alternative?
    Thanks.
    - Rutgar
  2. Cornelius
    Cornelius Stunt Coordinator
    Feb 24, 2004
    117
    No, that will change the impedance of the connections, which you don't want to do. You need a video distribution amplifier, such as the Niles Audio AVDA-3.
    CJ
  3. Rutgar
    Rutgar Second Unit
    Jan 17, 2004
    495
    I see. Is there a distribution amp for component video? I would have to buy three of the Niles Audio AVDA-3's, since they only have one video input.
    - Rutgar
  4. Cornelius
    Feb 24, 2004
    117
  5. Rutgar
    Rutgar Second Unit
    Jan 17, 2004
    495
    Okay. Thank you for the information. I Ordered the distribution amp from Cables to Go. I thought about a switch, but the one's I found were as expensive as the amp, and most of them were designed for multiple inputs, with only one output. Which, of course, wouldn't work.
    - Rutgar
  6. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    A manual non-powered video switch will also send one source to your choice of three or four TV's, just by connecting it backwards.
