Y/C Correction / Gamma Adjustment / Connections - Toshiba DVD Players
Discussion in 'Archived Threads 2001-2004' started by Martin Jeeves, Feb 21, 2002.
  1. Martin Jeeves
    Martin Jeeves Supporting Actor
    Oct 18, 2000
    694
    Could anyone tell me what the Y/C Correction and Gamma Adjustment features are on the Toshiba SD900E / SD9200 DVD Players. Should they be used? Are they a benefit on some transfers? What do they do?
    Also, given the choice of RGB Scart and S-Video connection on the SD900 / SD9200 Players. Which one is the better for a clearer, sharper, more lifelike (filmlike) image?
    Thank you,
    Martin.
  2. Martin Jeeves
    Oct 18, 2000
    694
    Anyone?
  3. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    I'll take a stab.
    If I remember correctly, the Y/C adjustable parameter affects the color timing/gap. There is usually only a small amount of correction adjustment allowed so play with it and see which gives better results, if any.
    The Gamma adjustment allows the neutral/mid-tones to be boosted/cut without affecting the highs (brights) and lows(darks).
    I have no experience with the SCART. My set tops out at Component and S-Video.
