Shawn Fogg
- Oct 5, 2001
Keith,
On the 5.1 inputs on the Yamaha do they go through its pre-amp section? If so it may be increasing noise+distortion and even effecting relative channel balance depending upon how well its volume control tracks all 6 channels.
"relative to some other potential solutions, though the Radio Shack boxes are still cheaper."
Heck, some people will suggest a 6 channel $3200 pre-amp as a solution.
All depends upon what you are looking for and the quality level desired. For example the relays in my switch box alone cost more then the complete R/S box.
Philip,
"Also, there is a resistor on each channel. I'm not sure if that's there for the 75 ohm "composite video" channel or not. It may be just to eliminate crosstalk between selections."
If it is on each channel it is probably there as insurance against any sort of noise when you switch sources. It will drop the level through the box (how much will vary upon the input impedance of your amp) and might reduce channel seperation. How much again depends upon the input impedance of your amp.
Shawn
Philip,
Shawn
