- Jun 10, 2003
- Josh Steinberg
I just started having a strange problem while trying to capture some DV.
I have a Panasonic Palmcorder PV-DV401 that's worked perfectly from the day I bought it. I'm using a fairly new Dell computer running Windows XP.
Normally, all I have to do is plug the DV camera into the computer's firewire card. Then the computer recognizes the camera, and everything works just fine.
I plugged my camera in, and nothing happened. I checked in the device manager, which said that the firewire card was working fine - yet it wasn't detecting my DV cam.
I tried removing the firewire driver and then letting Windows reinstall it automatically when the computer was rebooted. It did that fine, but it still doesn't recognize my camera being plugged in.
I tried three different cables to make sure it wasn't a cable problem. I also used my ADVC-100, and it didn't recognize that either, so it's not the fault of the camera.
I'm at a loss as to what to do. I'd appreciate any help or suggestions you might have -- my email address is [email protected] if you would prefer to email me privately.
Thank you for your time,
Josh
Josh
