Todd Hochard
- Jan 24, 1999
All,
I've been working on an upgrade from Win98 to XP (not a clean install- I know, I know), and I can't get the sound card to work.
The system is a Gateway PIII-600, with an AGP Voodoo3 card, and Sound Blaster Live! Value. Initially, in Win98, both the video and sound were on IRQ11, but worked fine. Card was in PCI slot 2.
I do the upgrade and no sound, but XP says everything is installed correctly. I go to Creative, get the latest drivers, and install. No sound.
Fine. I delete the card from XP, reboot and let it reinstall. It still goes to IRQ11, still no sound.
Fine, fine. I remove the card from XP, then from PCI slot 2, and put it in slot 3. Reboot, and it reinstalls at IRQ5, and I update the latest drivers. NO SOUND!
I'm at a loss. What gives? I run the same card on my PIII-667 with no issues. There seems to be no conflicts. Nothing else is sharing the IRQ. Windows says there is nothing wrong. I've been working with the system today via Remote Assistance, and it won't send sounds over to me, either. Yes, I've checked the Mute.
One thing that is curious- the computer has a Promise ATA-66 card for the HD. It was built like this from Gateway, even though it has onboard primary/secondary IDE?? There are 4 total IDE devices- HD, Zip, DVD, CD-RW- just like my PC, only I use onboard only.
HELP!
Todd
HELP!
Todd
