XLR --> RCA cable, what cable to use?
Discussion in 'Accessories, Cables, and Remotes' started by TimDean, Sep 21, 2005.
  1. TimDean
    TimDean Extra
    Jun 8, 2005
    23
    Need to make a 6 foot XLR to RCA cable, what kind of cable should I use? This is for the AVR's preout into external amplifier connection, unbalanced.
    THanks
  2. Phil A
    Phil A Producer
    Oct 1, 2000
    3,186
    44
    1,610
    Central FL
    Phil
    You should just get an adapter from places like partsexpress.com, markertek.com or even look at Radio Shack and then make whatever you would normally make. Does the AVR have RCA outs? If som you may just want to use those. No advantage to conversion.
  3. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    If the receiver has unbalanced outs use them, you'll get no advantage of balanced outs if you convert to RCA.
  4. TimDean
    TimDean Extra
    Jun 8, 2005
    23
    Sorry, I need to clarify.
    The receiver only has RCA outs. The amplifier only has XLR in.
    Do I buy a RCA patch cord and put an XLR connector on? Or do I buy an XLR cable and put a RCA connector on? Or is there a better cable to use?
    The RCA output is unbalanced of course...
    Thanks Phil's!
  5. Phil A
    Phil A Producer
    Oct 1, 2000
    3,186
    44
    1,610
    Central FL
    Phil
  6. Wayne A. Pflughaupt
    Aug 5, 1999
    6,207
    55
    9,110
    Katy, TX
    Wayne
    It doesn’t matter – same result in the end. You do know now to solder, right?
    Wayne A. Pflughaupt
  7. TimDean
    TimDean Extra
    Jun 8, 2005
    23
    OK, easy enough. LOL, yes, i can solder.
  8. Wayne A. Pflughaupt
    Aug 5, 1999
    6,207
    55
    9,110
    Katy, TX
    Wayne
    Okay, I’m going to backpedal: I think I’d add an XLR to an RCA cable, because it’s easier to solder XLRs.
    This is how you’ll probably want to make the connection.
    [​IMG]
    If it’s an older amp (i.e., late 80s or earlier) it might have pin 3 designated as signal (+). If so, change the connections accordingly.
    Wayne A. Pflughaupt
  9. TimDean
    TimDean Extra
    Jun 8, 2005
    23
    I have it hooked up as shown. Works fine. Thanks.
