Xbox VGA Adaptor
Discussion in 'Gaming' started by Jeff_S, Aug 23, 2003.
Tags:
  1. Jeff_S
    Jeff_S Agent
    Aug 27, 2000
    46
    Hi all,
    I did a search for posts on Xbox VGA adaptors but came up empty. Does anyone use one? If so, which one do you have and how do you like it?
    I will be using it with the VGA input on my Sanyo Z1 LCD projector. I plan on using the component inputs on the Z1 on a progressive scan DVD player. Any word on if/when Microsoft might release a first party VGA adaptor or an upgraded progressive scan DVD kit?
  2. Dave Falasco
    Dave Falasco Screenwriter
    Oct 2, 2000
    1,185
    Try searching the forum for "Xbox VGA". This has been discussed a few times in the past, including:here, here, here, and here.
    [​IMG]
  3. Jeff_S
    Jeff_S Agent
    Aug 27, 2000
    46
    I see what my problem was. I thought the search box at the top was searching all posts for this forum. :b
    Anyway, thanks for your help, Dave. I'll check out some of the past threads!
  4. Jake Gove
    Jake Gove Second Unit
    Dec 8, 1998
    326
  5. Dean Cooper
    Dean Cooper Supporting Actor
    Oct 23, 2000
    972
    3
    Well I ordered the one through Jake's link (thanks BTW!). Once I get it I'll put up a review.
    Dean
