Xbox problem
Discussion in 'Archived Threads 2001-2004' started by Andrew P, Nov 24, 2002.
  1. Andrew P
    Andrew P Second Unit
    Nov 2, 1999
    304
    I just hooked up Live and ive been playing for 5 days and last night my Xbox would not recognize any of my games? Does anyone know what may be causing this problem?
    If not, im off to Circuit City to buy a new Xbox since mine is a over a year old and I do not have an extended warranty.
    Andy
  2. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    If you exchange it, make sure you copy your saved games and LIVE data to a memory card...
  3. Masood Ali
    Masood Ali Supporting Actor
    Jan 31, 2002
    921
    Make sure it wasn't just a momentary problem. If you turn it off for about 10 minutes and it works fine afterwards, then your issue isn't too threatening. If it still continues to have disc read errors, and it occurs on more than one disc, then you should return it...but not before you at least try to sweet talk MS Customer Service into a deal for fixing your Xbox.
    I've heard limited cases of people getting free repairs out of the warranty period, depending on the CSR they talk to.
  4. Tim Markley
    Tim Markley Screenwriter
    Jun 12, 1999
    1,279
    Even out of the warranty period it will only cost $100 to get it fixed. That's still a lot cheaper than buying a new one. I would try cleaning it real good first, including running a lens cleaner through it.
  5. JustinT
    JustinT Stunt Coordinator
    Aug 13, 2001
    200
    Same thing happened to me. I couldn't get my xbox to read any games for about 3 days.
    I just left my xbox off for a few days, and then it started working again. Haven't had a problem since!
  6. Scott Varney
    Scott Varney Agent
    Dec 4, 2001
    46
    I was having the same problem... getting a lot of disc read errors. Based on somethign I read on the 'net, I erased the game files for those games I know longer own/play. And guess what... it worked. Not one disc read error since.
    Now, what old game files have to do with reading the disc is beyond me, but it saved me at least $100.
    One the other hand, the new bundle with Sega GT and JSR is a great deal. If I hadn't been able to fix the XBox myself, I would've just gotten that bundle. Not too much more expensive than the $100 the Microsoft is charging for repairs since I don't have either game.
  7. Jeff Kleist
    Dec 4, 1999
    11,267
