XBox Optical Cable Question (1 Viewer)
Daniel Swartz
I just discovered an old audioquest cable lying around and was curious if it was suitable for the 5.1 optical cable run from my XBox to my receiver. The cable is a blue, "video one", silver-plated copper audioquest with the following specs:
-22 AWG (UL)
-Type CL3
-75 degrees Cel
Now, the "video one" sounds like it wouldn't work for audio but I think I use the same type of cable currently in between my DVD player and receiver. I just can't get behind the cabinet to double check.
Any thoughts guys? Thanks!
Travis Olson
Travis Olson
:confused:
As long as the cable is optical with Toslink connectors I don't think there would be problem. I say hook it up and give it whirl, if it doesn't work, no big deal.
Alex Spindler
Daniel, you are describing a coaxial cable that you probably use for video and audio between your DVD player and receiver. What you need is a fiber optic cable, which doesn't have any copper at all. They generally have square 'toslink' interfaces, as opposed to the round coaxial cable interfaces.
At present, I think optical cabling is only used for digital audio and not for video in most HT applications.
Daniel Swartz
Thanks guys. Any idea on where I can get a 25 foot fiber optic cable with toslink connectors relatively inexpensively?
Joel Mack
I'm no expert, but 25 feet may be out of opticals effective range... You need to locate your XBox closer to your reciever...
Travis Olson
Travis Olson
25 feet is not out of optical's range. Here is a website that sells them in lengths up to 50 feet, very reasonably priced too.
CodeineD1
