Scott Hart
Xbox One X Preorder
Have you preorded your Xbox One X yet? Are you planning on getting one? Should you get one? Is your Xbox One S good enough? Personally, I want one. The pre-order is happening now, pretty much everywhere, to ensure that you get one on or around the release date. From the 100s of reviews that are currently online, most people say that it is pretty amazing. Of course, there are going to be the people that are simply not impressed by anything. To add to my barrage of questions, what about the PS4 Pro? Is that good enough for $100 less?
The new Xbox is going to be able to do some pretty amazing things, but can it replace your theater PC? This is going to depend on the user, but to remind you, here are the specs of the new XBOX:
Tech specs
CPU
Custom CPU @ 2.30 GHz, 8 cores
GPU
Custom GPU @ 1.172 GHz, 40 CUs, Polaris features, 6.0 TFLOPS
Memory
12 GB GDDR5 @ 326 GB/s
Flash Memory
8GB
Internal storage
1TB HDD
Optical disc drive
4K UHD Blu-ray
PSU
245W, internal
HDMI resolution and framerate
2160p @ 60Hz
AMD FreeSync
HDMI Variable Refresh Rate (when ratified)
HDR10 support
Yes
Content protection
HDCP 2.2
Video CODECs
HEVC/H.265, VP9, AVC/H.264, MPEG-2, MPEG-4 Part 2, VC1/WMV9
HDMI audio, encoded
Dolby Digital 5.1, DTS 5.1, PCM 2.0, 5.1, & 7.1; Dolby TrueHD w/Atmos¹¹ (from games)
HDMI audio, passthru
Dolby TrueHD (opt. Atmos¹¹), DD+ (opt. Atmos¹¹), DTS-HR/MA (opt. DTS:X)
S/PDIF audio, encoded
CODECs decoded
AAC, MP3, MPEG1, WMV
Connectivity
3 USB 3.0
2 HDMI (1 HDMI 2.0b out, 1 HDMI 1.4b in)
S/PDIF
IR receiver/IR Blaster port
IR Blaster
Ethernet (IEEE 802.3 10/100/1000)
Kinect (via external USB adapter)
Wireless
IEEE 802.11ac dual band (5GHz & 2.4GHz), 2x2 wireless Wi-Fi with Wi-Fi Direct for home networks
Accessories radio
Dedicated dual band Xbox Wireless radio
Dimensions
11.81 x 9.44 x 2.36 in (299.97 x 239.77 x 59.94 mm)
Weight
8.40 lbs (3.81 kg)
In the box
• 1TB Xbox One X Console
• Xbox Wireless Controller
• HDMI cable (4K capable)
• Power cable
• 1-month Xbox Game Pass trial
• 14-day Xbox Live Gold trial
Let me know your thoughts! Preorder pretty much anywhere that you would normally buy one!
Xbox One X Preorder
Tech specs
CPU
GPU
Memory
Flash Memory
8GB
Internal storage
1TB HDD
Optical disc drive
4K UHD Blu-ray
PSU
245W, internal
2160p @ 60Hz
AMD FreeSync
HDR10 support
Yes
Content protection
HDCP 2.2
Video CODECs
HDMI audio, encoded
CODECs decoded
Connectivity
3 USB 3.0
S/PDIF
IR Blaster
Wireless
Accessories radio
Dimensions
Weight
8.40 lbs (3.81 kg)
In the box
• Power cable
