XBOX: Loading Custom Tracks
Discussion in 'Gaming' started by Steven Simon, Nov 3, 2003.
Tags:
  1. Steven Simon
    Steven Simon Producer
    Sep 14, 1998
    3,276
    7
    Steven Simon
    Hey Guys,
    I'm trying to load up some custom music on my XBOX. Seems only media it will read is CD-RW... It's also taking forever to load the cd.. Is this normal???
  2. Jordan Raup
    Jordan Raup Stunt Coordinator
    May 3, 2003
    89
    yes it is normal for it to take a long time, and yes the only media it will read are regular cds and some types of cd-rws
  3. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    The new Xboxs, that come with the free Tetris Worlds and Star Wars Clone Wars, play CDrs.
  4. Keith_R
    Keith_R Screenwriter
    Jun 16, 2001
    1,170
    FL
    Kyle
    not to hijack the thread but I recently discovered that my XBox will not read CD-R's. I would like to do the same as Steve and load some custom tracks to my Box, is it possible that mine will only read CD-RW's as well?
    In case it helps, my XBox is fairly old, I purchased it in August 2002. Thanks.
  5. Steven Simon
    Sep 14, 1998
    3,276
    7
    Steven Simon
    I ran out to staples last night, and picked up a few CD-RW's... It worked fine in the XBOX, but took forever to copy..
  6. Tony Whalen
    Tony Whalen Producer
    Jan 29, 2002
    3,150
    Does anyone have a list of what brand of CDR's or CDRW's are readable by the 'box?
  7. Keith_R
    Jun 16, 2001
    1,170
    FL
    Kyle
  8. Dan B
    Dan B Screenwriter
    Sep 17, 1999
    1,389
    Generally speaking, it should read all CD-RWs & no CD-Rs...but if your Xbox has the Samsung drive it will probably read CD-Rs too. There are some compatibility lists out there...can't find my bookmarks at the moment though.
  9. GaryP
    GaryP Second Unit
    Jul 9, 2000
    264
    Here you go:
    Xbox Media compatibility list
    On a personal note I've found that Memorex CDRW's work great. I've actually found no CDR brands that worked on my box, just the RW's
    Also, other factors to consider are: the burning ROM you're using as well as the burner, apparently they can both play a factor in whether or not your particular media will be readable.
    Hope this helps,
    Gary
  10. Steven Simon
    Sep 14, 1998
    3,276
    7
    Steven Simon
  11. Mark Shannon
    Mark Shannon Screenwriter
    May 27, 2002
    1,991
    45 minutes for 10 songs, eh? Mine only takes about 15 minutes for a whole CD.
    Speaking of the music mixer... is it out yet? It allows you to transfer music from PC to xbox, I believe by uploading to a server and downloading...
    Make you any bet the RIAA monitors this.
    What I'd like to see is a game or something for the Xbox that allows us to use the built in Ethernet port to transfer directly from computers.
  12. CaptDS9E
    CaptDS9E Cinematographer
    Apr 18, 1999
    2,169
    actually music mixer is out and it transfers directly over your lan setup from pc to x-box or using a crossover cable. No uploading to some microsoft server and back again
    capt
  13. Rob Varto
    Rob Varto Supporting Actor
    Mar 5, 2000
    711
    I've got the Music Mixer and a Linksys Wireless G broadband router. I've had a heck of a time d/l music to my Xbox. Every time I try, I get a disconnect message. Anyone else have any luck / bad luck with this? Anyone have any suggestions for me?
  14. Len Cheong
    Len Cheong Second Unit
    Mar 18, 2000
    372
    It's probably the media you are using. I have Sony brand cd-rs and it takes 15-20 to copy to the xbox hard drive.
  15. CaptDS9E
    Apr 18, 1999
    2,169
    I used a Linksys wireless B router and i have no problems transfering using music mixer
    capt
  16. Mark Dubbelboer
    Mark Dubbelboer Screenwriter
    Oct 6, 1999
    1,008
    do rental places rent music mixer?
    That might be easier than buying cdr's
  17. CaptDS9E
    Apr 18, 1999
    2,169
    you need the music mixer cd to start up. It dosnt save music mixer to the x-box hard drive
    capt
  18. Rob Varto
    Mar 5, 2000
    711
    For the life of me, I cannot get this gd thing to work. I constantly get the "unable to connect to computer" message. It's bizzare, because I have no problem getting (and staying) online.
  19. Kyle McKnight
    Mar 8, 2001
    2,504
    Rob...my friends virus-protection had a firewall enabled. Didn't affect him getting on the net, but he couldn't connect to his XB. He just turns it off when transferring music.
  20. Christop_Holmes
    Christop_Holmes Stunt Coordinator
    May 31, 2003
    55
    Just load the songs up to a CD-RW and burn them, lock the disc and upload them to the xbox, it will work. from my experience the CD-R's wont work but the RW's will... Then just format it and keep doin it!
