Xbox live question
Discussion in 'Archived Threads 2001-2004' started by Martin_Frohlich, Dec 6, 2002.
  1. Martin_Frohlich
    Martin_Frohlich Stunt Coordinator
    Nov 13, 2000
    88
    I am getting Road Runner high speed internet access installed on Monday. Wasn't sure if I should put this in the software or hardware section. My real reasoning for doing this is to get Xbox live. I am somewhat computer literate but a little rusty. I assume I need to buy a router and then have the cable connection run into the router and then the router connect to both my PC and my Xbox (two different rooms). If so, what type of connections need to be run to my pc and to the Xbox from the router (is it coax cable)? Also, what router should I buy? Does it matter?
  2. Joe Szott
    Joe Szott Screenwriter
    Feb 22, 2002
    1,962
  3. Martin_Frohlich
    Nov 13, 2000
    88
    Thanks Joe. I actually believe I got my answer from Time Warner Tech dept but I will read the content over in your link as well.
  4. Shawn C
    Shawn C Screenwriter
    May 15, 2001
    1,429
    I just use a simple hub. I have my cable modem connection going to my hub, and then my computer and XBox connected to the hub.
  5. Jim Spencer
    Jim Spencer Stunt Coordinator
    Aug 22, 2001
    136
    I have a different question. Right now where I live (basement suite of a house) i have cable internet through my landlord. I'm thinking of moving in a few months, and i'll be getting my own cable internet hookup. If i get Xbox Live now is it possible to change the settings when i move and keep the same account information.
  6. GlenHaag
    GlenHaag Supporting Actor
    Sep 19, 2002
    973
    Yes Jim.
    As long as you have a Broadband connection to hook up to your Xbox, you can keep all the same account info.
    Glen
