James Nguyen
- Jul 30, 2001
found in the teamxbox forums:
Link Removed
Link Removed
Sent: 11/23/2001 6:28:54 AM
One of our forums members, Patience, has taken the task of
finding out how many blocks exactly the Xbox could hold,
50,000+ was all Microsoft put down on the spec sheet. He
copied a huge 77 minute CD to the HD. Then copied that set
of tracks onto itself. Then he repeated that process
several times. What he noticed was that you could only
hold 500 songs per sound track. So he copied that
humongous sound track to a new one. Dont get the idea that
you can only copy 500 songs. Its 500 per sound track. You
can have multiple sound tracks.
He maxed out the HD at 312,500 blocks!
Y2Kevbug11 did the math and figured out that it would take
5,297 GameCube memory cards told hold that, and at that
rate, at the GameCube's memory card price of $15, it would
be $79,459 to hold it.
