Xbox fan noise?
Discussion in 'Gaming' started by Mr. Brian, Jan 14, 2004.
Tags:
  1. Mr. Brian
    Mr. Brian Stunt Coordinator
    Nov 12, 2000
    59
    I just got an Xbox, and I was wondering if it's normal to have kind of loud fan noise. I don't really notice it when I'm playing a game, but it seems sort of loud if it's turned on and I'm not playing a game.
    Brian
  2. Vlad D
    Vlad D Screenwriter
    Oct 24, 2001
    1,076
    Vladimir Derenoncourt
    I recently got an Xbox and have noticed the same thing.
  3. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    It's fairly loud as a norm. Basically like a computer power supply.
  4. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Mine is loud as hell, I think the newer ones are supposed to be quieter. On the other hand after all the hours of play it only locked up once on a game.
  5. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,849
    728
    9,110
    Since 2006
    Cameron Yee
    If it weren't for the fan noise I might have actually considered using it for a DVD player.
  6. Brad_C
    Brad_C Auditioning
    Jan 6, 2004
    9
    I haven't ever noticed fan noise with my Xbox. I may if I listen for it, but it hasn't ever gotten my attention. It was manufactured in late 2003 if that matters.
  7. Rob Lutter
    Rob Lutter Producer
    Nov 3, 2000
    4,523
    I have a launch-day XBOX and it's loud as hell when I am playing CERTAIN games (Buffy and MechAssault come to mind)... which is sorta weird [​IMG]
  8. Brion Lydon
    Brion Lydon Stunt Coordinator
    Sep 20, 1999
    140
    I've never noticed any fan noise coming from my Xbox.
    Brion
  9. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    I got a launch-day xbox. It's loud, although quieter than most typical PCs.
  10. Mark Dubbelboer
    Mark Dubbelboer Screenwriter
    Oct 6, 1999
    1,008
    i have a launch-day set up as my dvd player in my dorm. it's brutal to try to fall asleep too.
    sometimes the disc drive makes noises too...it's going to die soon...i know it...i just don't want to accept it.
  11. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Yea no kidding. I came very close to shelling out ~$70 for another DVD player just so there'd be no fan noise. Too bad I'm a cheap bastid. [​IMG]
  12. MuneebM
    MuneebM Supporting Actor
    Jan 12, 2004
    621
    On the note of using the XBox as a DVD player:
    I managed to get my XBox to output DVD movies at 480p and it is not a very good quality player. Since its mostly software and less hardware, there's some serious pixelation. Test it out with Blade, chapter 15 @ 35:21 and look at the yellow wall in the background. My Toshiba SD-5700 is a much better player, and its ranked 40% by Secrets! So, that would put the XBox pretty low in that benchmark in my opinion.
    Mark Dubbelboer, if your DVD-ROM dies on you, just replace it with any IDE DVD-ROM for PC. That's the good thing about the XBox, its just like a PC so if something breaks down then you can most likely fix it quite easily.
