XBOX: DD & Composite video at the same time?
Discussion in 'Archived Threads 2001-2004' started by John M Miller, Dec 4, 2001.
  1. John M Miller
    John M Miller Stunt Coordinator
    Oct 20, 2000
    110
    My setup:
    Panasonic 27" TV with composite inputs only
    Outlaw receiver
    The bottom line:
    Is it possible for me to listen to dolby digital AND use a composite hookup at the same time?
    The way I understand it, the HD pack only has component hookups (no composite). I'm not sure about the advanced pack. Can I use it with my system or will I have to upgrade my TV before I can bask in the goodness of DD?
  2. Jeff O.
    Jeff O. Stunt Coordinator
    Jun 12, 1999
    190
    John,
    While I haven't tried the composite connection, the advanced AV pack has both S-video (that I use) and composite connections as well as the digital output. You can use your own digital optical and composite cables and you should be fine.
  3. Dan B
    Dan B Screenwriter
    Sep 17, 1999
    1,389
    Yep, the Advanced AV pack works for composite video and optical audio output simultaneously.
    -Dan
