Xbox component sammy dlp hookup problem
Discussion in 'Gaming' started by mike jau, Oct 5, 2003.
Tags:
  1. mike jau
    mike jau Auditioning
    Jun 21, 2003
    6
    hi i recently bought an xbox and got the component cables for it and im hooking it up threw the component 2 or 3 inputs which are auto sensing for 480p, 720p, and 1080i. and the only way i can get it to work is by using component 1 which only accepts 480i, and 480p signals when the xbox is set to 480p. but being as though the nature of my screen is 1280x720 seeing that format streched makes all the borders on graphics look like a saw blade butstill though the color is better than with composite cables. so basicly all im trying to find out is what do i need to do to fix this i mean im sure theres other owners of this tv that own an xbox and have had similar problems or perhaps found a solution and o ya my tv is the hln seris dlps 43 inch and thanks in advance
  2. NathanS
    NathanS Agent
    Mar 14, 2002
    30
    Make sure 480p, 720p, and widescreen are selected in the xbox's dashboard. Also don't forget only a hand full of games support 720p.
