Xbox communicator (1 Viewer)
Chad Ferguson
Just a quick question for those of you who own a xbox headset. If I was to purchase it, would I be able to hook it up to my computer and use it for CS as well? I noticed it looked like you could take out the headphone jack thing so I was just curious if I could get two birds with one stone.
THanks
KevinRB
I can't confirm, but the Xbox communicator does use some sort of standard plug. My cordless phone has an option jack in in it, and I can plug my communicator into it. Both the speaker and mic function perfectly.
Dave Bennett
standard pc headsets use 1/8" size plugs while the XBox communicator uses a 1/16" plug. You'd need some type of adapter to use it on your PC. It works great with cordless/cell phones though ;)
NHCondon
