Xbox and a cable modem router, possible?
Discussion in 'Archived Threads 2001-2004' started by Scott FP, Jun 17, 2002.
  1. Scott FP
    Scott FP Agent
    Nov 12, 2001
    39
    I recently installed a cable modem. I have used Netgear's cable modem router to hook up 3 PC's but will plugging in a Xbox to the router be the same thing?
    I want to be able to run Cat 5 direct to the Xbox without unhooking from my PC. Has anyone ever tried this?
  2. Ryan Peter
    Ryan Peter Screenwriter
    Sep 15, 1999
    1,220
    Should work fine.
  3. Kevin Coleman
    Kevin Coleman Second Unit
    Jul 3, 1999
    495
    Works good for me. I play Halo online all of the time like that.
    Kevin C. [​IMG]
  4. Larry Seno Jr.
    Larry Seno Jr. Supporting Actor
    Feb 28, 2002
    527
    It will work Dandy. Think of the Xbox as a computer in a REALLY cool case.
  5. Dean DeMass
    Dean DeMass Screenwriter
    Jun 30, 1997
    1,826
    Plug it in a port just like it was a PC. The same will be done for the PS2.
    -Dean-
  6. John Nielsen
    John Nielsen Stunt Coordinator
    May 11, 2001
    63
    Works fine for me. After you plug it in, go to www.gamespy.com, download the xbox tunnel software, then play some Halo.
  7. Morgan Jolley
    Morgan Jolley Lead Actor
    Oct 16, 2000
    9,055
    160
    9,110
    It better work fine. When I get my PS2 adapter and X-Box, this is how they're getting hooked up.
