Xantech 791-44 not firing IR on the emitters
Discussion in 'Home Theater Projects' started by Simon Ngan, Mar 15, 2004.
  1. Simon Ngan
    Simon Ngan Stunt Coordinator
    Feb 19, 2003
    99
    I just got one of these Xantech 791-44 expansion block and I don't think it's working. It's receiving signals as I can see the red LED is blinking whenever I press a button on the Marantz RC9200 remote (I'm using the RF to IR module from Marantz).
    However, on the dual emitters, none of them is firing and I get the lighted emitters and no light at all.
    I'm not sure if it's just bad luck I got a bad unit?
    Anything I can try to troubleshoot?
    Thanks for your help,
    Simon
  2. Cornelius
    Cornelius Stunt Coordinator
    Feb 24, 2004
    117
    Are you trying to wire the Marantz RF receiver directly to the expansion block, or are you using an IR receiver?
    CJ
  3. Simon Ngan
    Feb 19, 2003
    99
    CJ,
    The Marantz RF receiver has 4 IR emitters out but I need more for all the gears I have. So I bought this expansion block and I take a mini-jack cable to go from one of the emitters from Marantz to Xantech IR Receiver IN.
    I can confirm Xantech is receiving signals as there's a LED on the Xantech blinks whenever I hit a button on the Marantz remote. However, none of the output emitters work on the Xantech.
    Simon
  4. Cornelius
    Feb 24, 2004
    117
  5. Simon Ngan
    Feb 19, 2003
    99
    CJ,
    Thanks for the links, I'll check them out.
    I actually have the Xantech Hidden Link which has the expansion block - 789-44. It works fine with the Marantz RF receiver and I was hoping the 791-44 would work just the same and swap them out.
    Looks like it may not be this easy.
    Thanks again for your information.
    Simon
  6. Simon Ngan
    Feb 19, 2003
    99
    I was playing around again tonight and found out I need to use a stereo mini-jack cable into the 491-44. However, the cable I was using for 489-44 is only a mono mini-jack cable. I tried a stereo cable but no difference. I wonder somehow the Marantz device takes mono only?
    They are willing to swap with another Xantech but I'm just trying to find out more information.
    Simon
  7. Cornelius
    Feb 24, 2004
    117
    Also, note that in the last link I showed you, the person had to put the mono cable into the high output jack!
    CJ
  8. Simon Ngan
    Feb 19, 2003
    99
    CJ,
    I went through that thread on RemoteCentral but I'm going from the Marantz to the Xantech so I don't see why plugging into the Xantech Output would work.
    Simon
  9. Cornelius
    Feb 24, 2004
    117
    I know- me neither. However, the person posting is a custom installer who installs several hundred systems a year and does know what he's talking about. You might want to respond directly to the post or PM him.
    CJ
  10. Simon Ngan
    Feb 19, 2003
    99
    CJ,
    You're the best [​IMG]
    I plugged the Marantz RF out into Xantech High IR Out and it works.
    I'm about a bald man now trying to figure out this weird connection [​IMG]
    Thanks again for your assistance.
    Simon
  11. Cornelius
    Feb 24, 2004
    117
    I don't know the reasoning either- just glad it worked out for you.
    CJ
