X1 and firmware upgrade
Discussion in 'Displays' started by Jim Mcc, Sep 11, 2004.
  1. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I bought an X1 1 week ago with a 14 day trial period, and it has the 4.1 firmware, needs to be updated to the 4.3 version. How hard is it to do, and what is the cable I would need to do it? Do you hook up X1 to your computer and download from Infocus' website? If I took it back to Circuit City(where I bought it) could they do it for me? Do all projectors require periodic firmware updates? Thanks.
  2. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    Until you've decided to keep it I wouldn't upgrade the software.
    Go here
    and download it, read the instructions.
    Pretty simple really.
    Brent
  3. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Why does it NEED to be updated? the only thing 4.3 adds is less susceptibility to loosing sync on a HD signal.
  4. DaveGTP
    DaveGTP Cinematographer
    Jul 24, 2002
    2,096
    Don't upgrade it unless you need to. The upgrades only address a couple of specific problems that come up. If you're not having problems, leave it alone.
    And all you need is a standard USB cable. I swiped the one from my cable modem for a few minutes.
  5. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Nick, I want to hook it up to my Dish Network 811 HD receiver. I think I'll check if Circuit City would do it(that's where I bought it). Thanks.
