X-Files(TV ) on reg 2(PAL) :Higher resolution than reg 1 version?
Discussion in 'Archived Threads 2001-2004' started by svante, Sep 29, 2002.
  1. svante
    svante Auditioning
    Apr 19, 1999
    2
    The X-files Season 5 is soon to be released on Reg 2 and
    now I'm wondering if this would theoretically give me better picture resolution than on the reg.1(NTSC) DVD's.
    Is the original master limited to the NTSC resolution?
    In that case I could as well buy the Reg 1.
    In fact the Pal could actually be worse than the
    NTSC because of the NTSC-PAL conversion, right?
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    Yes they're taken from NTSC masters from what I'm told, and yes, PAL is probably a little worse because of conversion
  3. Duncan Harvey
    Duncan Harvey Stunt Coordinator
    Mar 27, 2000
    198
    well it certainly shouldnt look any worse, as modern conversions can look superb and unnoticable picture wise. But of course any "extra" resolution will only be interpolated rather than genuine.
    But unless pitch corrected it will suffer from the speed up if its a DEFT conversion.
  4. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
    Actually...from what I've heard...there is no speed up with TV. Only film.
  5. Jeff Kleist
    Dec 4, 1999
    11,267
    Craig, except that most US TV shows are shot 24fps, so are still subject to speedup
  6. Duncan Harvey
    Mar 27, 2000
    198
    exactly - with the DEFT process the NTSC master has the pull down removed to get back to the 24 frames/48 fields per second and is then sped up to the PAL standard of 50.
    This explains why so many US 45 minute episodes clock in at around 43 when DEFT converted to PAL. If you dont "know" about it then to be honest its not a problem. DEFT does give a remarkably good picture and when comparing a DEFT con to an NTSC original its difficult to tell which is which when the sound is down.
  7. Darren Lewis
    Darren Lewis Supporting Actor
    Jul 17, 2000
    534
    I've watched season 1, and have nearly finished season 2 on Region 2 PAL, and I haven't noticed any problems. I guess that unless you do a direct A-B comparison you wouldn't notice.
    Darren.
