X-BOX not working?
Discussion in 'Archived Threads 2001-2004' started by Brad Jay, Dec 27, 2001.
  1. Brad Jay
    Brad Jay Agent
    Dec 1, 2001
    37
    I set up my X-BOX no problem and then played it for about an hour. Everything worked great.
    I then left and went out for lunch and when I got home I tried to play it again and the green circular light flashes green then orange alternately and the disk will not spool up.
    In the instructions it says that those symptoms indicate the AV cord is not hooked up correctly but its kinda obvious how to hook it up and it worked perfect earlier. Has anyone else had a similiar problem?
  2. Derrik Draven
    Derrik Draven Supporting Actor
    Dec 7, 1998
    935
    Chris
    You may have the cords hooked up correctly but, did you check to see that they are hooked up securely?
    If they come loose, you'll get the same flashing light.
