Elbert Lee
- May 24, 2000
I'm pretty much decided on an X Box for my next game system but I'm a bit confused. I have an hd ready set and 7.1 surround so plan to use all of the x box features.
Monster Cable and x box sells the component video connection with analog audio outputs. I don't notice any optical or coax digital outputs on the console. Does this mean that I have to purchase the "Advanced A/V pack" in order to get 5.1 and a progressive scan image? BTW - I also didn't notice any optical outputs on the Advanced A/V pack.
What is the best way to hook it up? Use the advance av pack or go direct with Monster's component video?
Thanks for the help?
Elbert
Elbert
