WOW! Unusual Tweak for Tubeheads
Discussion in 'Archived Threads 2001-2004' started by Lee Scoggins, Jan 14, 2002.
  1. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,394
    Lee
    Friends,
    Today I installed Audio Research tube rings on my 6922 output tubes in my VT100.
    Wow! Tighter soundstage. Purer midrange, Crisper highs..
    I'm in heaven. I guess eliminating microphonics matters.
    And a cheapie too - $4 per ring, two rings per 6922 or 12AX7.
    Lee
  2. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
    No tubehead interest?
    I swear this stuff works. I wanted to like transistors but I still like tube midrange better, even though the Pass Labs amps do it well.
    Lee
  3. Frank_S
    Frank_S Supporting Actor
    Oct 28, 1999
    565
    Lee, I have all SS gear except for my phono stage. I have an EAR834P that I love. I'm currently rolling tubes to find the best combo and have also swapped the coupling caps with Hovland musicaps. I suspect I will be purchasing more tube gear in the near future. What are tube rings, I have seen tube socks. Where do you purchase? I also use 12AX7's. [​IMG]
  4. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
    Frank,
    I bought them through Sound and Cinema, my local high end store. They are available from Audio Research for $4 each.
    They are polymer rings that just fit on the end of 6922 or 12ax7 tubes and they keep the tube mechanically rigid to dampen microphonics. They work! and the tweak is so cheap I thought it would generate some interest.
    A bunch of Atlanta audiophiles use them religiously on tube preamps and amps.
    Lee
  5. Frank_S
    Oct 28, 1999
    565
    Thanks for the response lee.
    Do you need 2 for each 12AX7 tube?
    I'd like to give them a try! [​IMG]
  6. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
    Frank,
    Yes, that's two per tube, right on top of one another.
    I found it made a BIG difference on my system.
    Enjoy,
    Lee
