Wow! Finished my MkII Titanic/PE 250 watt amp combo
Discussion in 'Archived Threads 2001-2004' started by Eric Massey, Jan 6, 2003.
  1. Eric Massey
    Eric Massey Agent
    May 21, 2001
    31
    After a weekend of inhaling MDF sawdust I finally finished making the enclosure for my Dayton Loudspeaker Titanic mkII 12" Titanic and my partsexpress 250 watt amp.
    The internal volume is roughly 4 cubic feet and I used a 4" flared precision port to achieve a tuning frequency of 22hz. After hooking this baby up, all I can say is WOW. Even with the volume about halfway up, pictures were falling off the wall, I could visibly see molding on the walls flexing, and light fixutres were rattling in adjacent rooms.
    But as we all know, volume isn't what it's all about. On everything from Bach Organ to Heavy Metal rapid-fire double bass, I found this sub to be quick, accurate, and overall very musical. On anything below 40hz it really knocks your socks off.
    To finish the project, I wrapped the MDF in Partsexpress black ash vinyl laminate. This was my first time with the stuff, so the finish isn't perfect (edges not perfectly flush in some places, sides not perfectly smooth) but from more than 3 feet away I can't notice anything, and it looks good enough for the dorm room it's going in!
    Here are some pictures for anyone interested, but you'll have to cut and paste the url's into your address bar since Geocities won't let me link to them on here.
    http://www.geocities.com/erichmassey/wooffront.jpg
    http://www.geocities.com/erichmassey/woofbot.jpg
    http://www.geocities.com/erichmassey/woofback.jpg
  2. george king
    george king Supporting Actor
    May 29, 1999
    625
    This is pretty much the sub that I was thinking about, except in a sealed box. A quick question, what are the outer dimensions of your box.
    Thanks a bunch
  3. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Eric,
    The sub looks great. From what you've described, it must sound even better.
    Have you calculated what your total cost outlay was for this project? I'm sure you're probably under $400.00.
    Also, if there were some areas of the MDF that the vinyl didn't cover, you could always use a permanent black marker to make some touch-ups, if needed.
  4. Eric Massey
    Eric Massey Agent
    May 21, 2001
    31
    George:
    The box is 21" x 21" x 21" and the legs are 4" wide x 4" long x 4.25" tall.
    The sub cost $150 from partsexpress and they had the amp on sale for $119.00. The port tube cost about $12.00 and the sheet of MDF was $30.00.
    So, the total cost was about $310.00.
