dan scorpio
- Jan 19, 2003
i have 2 50 watts pro's attached to my couch and simply love them...the thing is i also only have a 50 watt at 8 ohms amp plate,i have to run it at about 90% to get a good effect,i will eventually buy a new 6.1 receiver,and then i will use my old 5.1 receiver to run the shakers.....
my question is running my amp plate at 90% going to hurt the shakers or my amp? because i guess i am sending distortion to the shakers if running at full? but then again they say you do not need much power to run these and does not have to be clean power....thanks for the answer in advance.....
