I'm looking to buy my first HDTV and I've recently found a store which is selling the BenQ DV2680 for around 900 dollars Canadian. They are having a huge sale and I'd save around 500 dollars from the original price.
Here are the specs taken from benq.com (I'm not allowed to post URLS since I'm a new user):
Model DV2680
Screen * * * * * * * * * * * * * * * * * * * * *
Screen Diagonal
(cm / inch) 66 / 26
Aspect Ratio Wide Screen
Brightness
(cd / m²) 600 nit
Contrast Ratio 600:1
Response Time 16 ms
Viewing Angle
(H / V) 0 / 0
Resolution 1280(x3) x 768 dots
TV Broadcast * * * * * * * * * * * * * * * * * * * * *
HDTV Compatible 480p / 720p / 1080i
Broadcasting System NTSC / PAL / SECAM
Audio * * * * * * * * * * * * * * * * * * * * *
Sound Effect Stereo
Speaker 10W x 2 Bulit-in
Video * * * * * * * * * * * * * * * * * * * * *
Senseye Technology No
10 Bit Color Processing No
Independent Four-color
Adjustment No
DCDi No
Aspect Ratio
Adjustment --
Picture Modes --
Personal Setting No
De-Interlacing Yes
3D Y/C Comb Filter Yes
Features * * * * * * * * * * * * * * * * * * * * *
PIP/PBP Yes
Picture Freeze Yes
Child Lock /
Parental Control Yes
Backlight Eco Mode Yes
Color Temperature --
Sleep Timer Yes
PC Mode * * * * * * * * * * * * * * * * * * * * *
Image Auto Setting No
Horizontal Frequency 31.5 ~ 60 KHz
Vertical Frequency 50 ~75 HZ
DPMS No
Input Terminals * * * * * * * * * * * * * * * * * * * * *
Composite AV (3 Cinch) Yes
S-Video Yes
Component
(Y Pb Pr / Y Cb Cr) + Audio Yes
D-Sub Yes
PC Audio Yes
DVI-HDCP+Audio Yes
RS 232 No
Output Terminals * * * * * * * * * * * * * * * * * * * * *
Headphone No
Audio Out No
General Information * * * * * * * * * * * * * * * * * * * * *
Dimension
(with stand , W x H x D mm) 850 x 444 x 87
Dimension
(without stand, W x H x D mm) 850 x 503 x 3
Weight
(with stand, Kg) 15
Weight
(without stand, Kg) 12
AC Input --
Power Consumption
(W) 160
Accessory * * * * * * * * * * * * * * * * * * * * *
Remote Control
with Battery Yes
Wall Mount Kit Fixed
I'm going to use this TV primarily for video games and for watching movies on DVD. I don't really know too much about high definition televisions, though I'm learning more and more everyday and I hope you guys can help me out. Would you guys recommend this TV? Thanks a lot!
Oh and the aspect ratio for this tv is 15:9. When watching wide screen movies, will that squish the image so much that it's noticeable?
Model DV2680
Screen Diagonal
(cm / inch) 66 / 26
Brightness
(cd / m²) 600 nit
Response Time 16 ms
Viewing Angle
(H / V) 0 / 0
Sound Effect Stereo
Adjustment No
DCDi No
Aspect Ratio
Adjustment --
Picture Modes --
Personal Setting No
De-Interlacing Yes
PIP/PBP Yes
Picture Freeze Yes
Child Lock /
Sleep Timer Yes
DPMS No
S-Video Yes
Component
D-Sub Yes
PC Audio Yes
DVI-HDCP+Audio Yes
RS 232 No
Headphone No
Audio Out No
Dimension
Dimension
Weight
(with stand, Kg) 15
Weight
AC Input --
Power Consumption
(W) 160
Remote Control
with Battery Yes
