Would using component cables as interconnects to an amp be better than rca?
Discussion in 'AV Receivers' started by DarL, Mar 24, 2004.
  1. DarL
    DarL Agent
    Jan 18, 2004
    25
    Would using a component cable as an interconnect for an external amp better than using a cheap RCA cable from radioshack? I currently own a Denon 3803 and are using the preouts with component cables to my exteral parasound amp. My question is that would this setup ruin my speakers or equipment, and does it make the audio sound worst or better?
  2. Paul S
    Paul S Stunt Coordinator
    Nov 2, 2003
    93
    Chances are, you won't see any difference whatsoever. Give it a try. You can't hurt anything!
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Component cable is usually higher quality than most "std" audio interconnects because it's always shielded, coax, usually RG-6 or RG-59 cable. In fact, www.bluejeanscable.com uses this very stuff for audio interconnects.
    But. Some of the Radio Shack stuff is quite good too.
