Would this really work?
Discussion in 'Archived Threads 2001-2004' started by TreyP, Oct 30, 2001.
  1. TreyP
    TreyP Stunt Coordinator
    Oct 3, 2001
    122
  2. Michael St. Clair
    May 3, 1999
    6,001
    Picture will be dim and lacking in resolution.
    Might be OK for a background lightshow at a party.
  3. TreyP
    Oct 3, 2001
    122
    But it 'will' work?
  4. NathanP
    NathanP Supporting Actor
    Aug 13, 2001
    841
    It'd work fine, but it would be a bit dimmer than regular tv.
    You also have to build stuff when doing this and turn your TV upside down to have it work properly..
  5. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    If you look closely, the kid with the sign is the exactly the same in each picture. This would lead me to believe they just superimposed the kid over a picture of a TV rather than an actual photo of him in front of a screen.
    I like how they changed the font on the sign to make it look like it's not the same kid.
    But it would be interesting to see how it worked.
  6. DustinDavis
    DustinDavis Stunt Coordinator
    Dec 26, 1999
    171
    If you look even closer, it appears the kid must be a vampire or something as he casts no shadow on the screen.
    Dustin A. Davis '94
    Dustin Davis for Dummies : My HT : Dallas HT Group
    "But they are useless. They can only give you answers." - Pablo Picasso on computers
  7. DaveF
    DaveF Moderator
    Mar 4, 2001
    17,986
    1,545
    One Loudoun, Ashburn, VA
    David Fischer
    This is very likely a large, plastic Fresnel* lens with instructions for positioning it. The Fresnel lens is used to image the TV screen onto the wall, hanging sheet, etc. As pointed out, you'll have to turn your TV upside down, for this configuration. You'd probably have to turn the TV brightness and contrast all the way up as well.
    Would it work? Probably. There could be significant color distortion, plus the general hassle of setting it up. Of course, it's far cheaper than a big TV, and might work well for parties, as someone suggested.
    * like the ones that used to be put in the rear windows of Motor Homes, to help with the rear-view mirror. Large, thin plastic lens, with bevels cut in the plastic to provide the lens power.
  8. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    I believe you are right in pointing out that the "projected" image in the pictures aren't actually projected. The other tell tale sign is that there is no parallax at all between the image which is on the sign vs the image on the screen. In real life, the placard would be some distance in front of the screen (in order to fit the kid). The only time you would see no parallax displacement of the image plane at the placard vs the plane of the screen would be if the camera lens was also on the axis of the projector. Gee, must be an absolutely amazing lens to still throw a good picture with the camera smack dab in front of the lens.
    Guy Kuo
    www.ovationsw.com
    Ovation Software, the Home of AVIA DVD
